gregk9
Any preference here? I'm assuming the external would get better reception, no?
gregk9 said:Any preference here? I'm assuming the external would get better reception, no?
russ010 said:I've got internal on my 788ci - and I have had no problems.. even when it was under the tree the other night
I would go with internal if you have an open boat - it's one less thing to worry about running wires for or worry about getting damaged.
wasilvers said:Only issue I have is if you mark a location going north, then go back south, you could be a good 15 feet from it - assuming it marks 'just the right spot".
gregk9 said:wasilvers said:Only issue I have is if you mark a location going north, then go back south, you could be a good 15 feet from it - assuming it marks 'just the right spot".
Do you think that's an antenna issue or the unit itself?
wasilvers said:gregk9 said:wasilvers said:Only issue I have is if you mark a location going north, then go back south, you could be a good 15 feet from it - assuming it marks 'just the right spot".
It's just the difference of the transducer being 8 feet behind my internal gps unit. If you have an external antenna, you just mount it above the transducer and you are as close as you can get.
