Ryno409
I believe I have everything I need to put my Mirrocraft together. My last question is, should I have a switch connected to the battery that is going to power everything but my trolling motor? I have everything running into a fused switch panel and grounded into a bus. Would anyone recommend a wiring a switch that would kill power to the panel in case something happened, or should I put a circuit breaker, similar to what is on my trolling motor?
Crap. One last question. My trolling motor came with 10awg wire. Should I run that size into the anderson connectors? I've seen where others recommend 8.
Thanks as always!
Thanks as always!
