Kyle's 14' Jon
LSGUNSS
Columbia, MO
Hey guys. I'm new here but not new to forums or building things. First off my name is Kyle and I am in Columbia, Mo. I have rebuilt a few tractors, built a few cars/trucks and this will be my first boat to mod. Please let me know what you guys think and if you have any suggestions for me I am open to them.
My tractor Ferguson TO35 that I restored last year with my dad:
My current "hot rod" 2000 Chevy S10 with a 5.3, heads, cam, intake, exhaust, tune, 3000 stall bla bla bla:
My boat. 14' 2007 Tracker w/livewell. I already added the bows under the cover to help rain run off:
I have started working on the motor which is a 1972 merc 110 9.8. This boat has been setting for 4 years unused so the motor wouldn't run just hit a little. So I took the carb off and cleaned it up...
after that it would run but not spit any water out so I figured it's time to check the water pump...
and it's time for a new water pump.
This can was the 1972 can that went with the motor but it looked like it could use some love so I painted it.
Before:
After:
Looking good. How's the inside of the can? Also you may want to upgrade the hoses. Most of those older ones are not rated for ethanol.
[url=https://www.tinboats.net/forum/viewtopic.php?p=355418#p355418 said:
huntinfool » 11 Jun 2014, 06:07[/url]"]Looking good. How's the inside of the can? Also you may want to upgrade the hoses. Most of those older ones are not rated for ethanol.
Thanks! I have already upgrade/replace on of them and I plan on replacing the other.
[url=https://www.tinboats.net/forum/viewtopic.php?p=355786#p355786 said:
LSGUNSS » 14 Jun 2014, 17:46[/url]"]
[url=https://www.tinboats.net/forum/viewtopic.php?p=355453#p355453 said:
SumDumGuy » 11 Jun 2014, 12:06[/url]"]I like the tractor. I have been somewhat considering rebuilding something and a tractor is near the top of the list.
Thanks man, This one was my first father son project with my father so It wont be going anywhere. I will say when you want to do them "right" is tough to do.
I got my water pump rebuild kit today and installed it. The ol' girl started peeing just like she should. I also worked on adjusting the carb set screw and the idle. I think it have it dialed in because she runs like a top and starts first pull every time now. I also found a ground wire that has seen better days. lol I fixed that too.
