littlejohn
Hello all. I bought the boat below just yesterday morning and happened upon your site about ten minutes after I got home with it. It's a 1972 14' made by Sears and has been sitting in a barn for the past three years.
The seller had it out in his back yard Friday and it stormed something fierce here. There was nearly two inches of water sitting in it when I got there. At least I know there aren't any leaks! I kept the plug out on the way home; people behind me loved me. I left it sitting outside all day and all of the water evaporated.
I ripped out the carpet this evening to find water standing under it. My problem is I can't figure out for the life of me how to get the seats out. There is an aluminum plate riveted to the factory aluminum. The swivel base is screwed into the plate. The carpet was then put down, then the swivel base was bolted down, then the seat was attached. Can anyone clue me in on what I'm missing?
The plans:
I'm going to apply several coats of Herculiner to the inside to cover all the aluminum and then will lay down perforated floor tile. I was thinking about gutting the front seat box to put my new Optima blue top in, but I discovered there's a giant foam block in there. I don't really want to sacrifice my flotation, so I'm trying to decide if I really want to do it or not.
I did find a few hole in the hull along the gunwale on both sides of the boat and plan to re-use them as mounts for my homemade rod holders.
Add some short risers under the seats. I would like them a little higher.
I have to build a front transom. I discovered after pulling the carpet that the rivets holding the handle to the front of the boat are starting to pull through and the aluminum around them is starting to crack. This is due to the boat being on a trailer set up for a V-hull boat. The handle rests on the wheel up by the ratchet and puts a lot of stress on it. The eye bolt you hook it to the trailer with is also starting to pull through. I'm going to cut a template and mount a piece of 3/8" plywood up there to strengthen it all up.
Other than that, I figured out last night I can put a 15hp motor on it. That's well into the future though. For now I'm going to run my great grandfather's 3hp outboard.
Great site here. I love seeing everyone's mods!
The plans:
