gah319
OK, so I am getting the wood decking cutout and dry fit. Most of it will be covered with carpet. The underside of the floor will be varnished. The top side of the floor will be partly carpeted (where you can stand on it) and partly painted (under the benches). So my question is under the carpet area can I just paint instead of doing the spar varnish? I will be using a HVLP sprayer to put on the paint so I can get multiple light coats on. Will the carpet glue hold over time? Should I varnish everything and then paint over that? I'm about a week away from this step, so chime on in...
