Thought I'd throw this out there for those who may be experiencing issues with their control pedal.
I bought my V2 last March.....this winter I was cleaning my boat in the garage and accidentally stepped on the pedal...but noticed the blades didn't turn like they should have....so I took a closer look. Between mid-range speeds on cont or momentary it did not work.
last year while fishing I thought at times I was running out of battery and I could only fight current/wind at high speed....stupid me for not realizing the pedal wasn't working.
I called Minn-kota, they suggested dunking it in water to clean dirt out....so I did...and it actually worked...until it dried out...then same problem.
So Minn-kota told me to bring it to a dealer to have a look...was still under warranty. (had to bring both the pedal and motor in) The guy took a quick look at the pedal for dirt...but there wasn't any....said it was a bad contact board where the magnet slides.....they ended up replacing the pedal under warranty. Just picked it up yesterday.
After only a year use...and I don't fish hard...maybe once a week...Sounded to me this was a common problem.....has to be a design issue.
Just thought this may help some of you out experiencing problems.
Also, if you have any aftermarket parts on your motor that didn't come with it, it will void the warranty....and I mean even minn kota parts.....only one that doesn't is the mounting bracket. Weed props, i pilot, etc will all void the warranty.
