Stringer Drain Holes before Foam?
BLindahl
Elk Grove Village, Illinois
So while power washing the subfloor out i had to use the shop vac to get water out of the side areas. Was thinking of drilling small holes in stringers, towards the rear, in hope to have all water drain into center of boat and to bilge. What to do? Or just seal with Gluvit and Install foam?
If the manufacturer is still around I'd call and see what they say. My vee hull has the same issue.
