transom holes in Topper 1542
pezz1961
Can some one tell me if wood transom needs to be removed to weld up holes in transom of a 1542 topper boat. I yes , then how?
You could weld it without removing it for sure. Might damage it some in the process though. Really comes down to whether or not it needs replaced to begin with imo. If it's solid than weld away, if it's rotten or soft, weld and then replace it.
I had 4 or 5 holes on my transom welded up. No Fire, no damage to the wood, & ground down smooth so you cant tell that it ever happened.
Adding power tilt and trim. It's after market and a different bolt pattern.
For larger holes ( nickel size or bigger ) I'd get a piece of aluminum plate cut to fill in most of the area of the hole & have it welded in. This mainly has to do with the skill & experience of the welder involved. It never hurts to get an opinion from the welder on what can be done.
