Used Parts
BrazosDon
Colleyville, Texas
I am about my wit's end trying to find some used parts for my '65 Johnson 3hp motor.(JW-20B) Is there anyone out there that might know where there is a vintage outboard bone yard that I could contact for parts? I am looking for the fuel cut off valve and filter and the handle that is attached to the lower cowling. Any help will be greatly appreciated.
BrazosDon
Found this one day when Googling don't know any thing about them. https://www.salvagemarineparts.com/index.html
Here are some options:
There is a fella, that lives in Dickinson, Texas that has alot of Johnson/Evinrude used parts. He can send you pictures of your parts prior to purchasing. I know he definitely has parts for 3hp Evinrude and Johnson motors.
Here is a quote of his from the Webvertise ad.
For Sale OMC parts only: 1/1/2 hp to 35 hp. Lower units, internal gears, drive shifts, complete power heads, blocks, cranks, pistons, recoils for most all omc motors, Aluminum and SS props. starter setups for older 18-25 hp 22 cu in 5" extension kits for 6, 7.5/8, 10-25 hp. Fuel pumps, coils, power packs. no 9.9 or 15 hp parts.
BLC (his handle on Webvertise portion of the AOMCI forum)
Bobby Chapman
Dickinson, Tx
713-705-0664
[email protected]
You can try posting a free Webvertise WTB (want to buy) ad at the AOMCI (Anitque Outboard Motor Club Inc) website. A lot members have spare parts, motors, and parts motors. Salvage yards often troll through the ads for prospective buys.
Here is the link to AOMCI Webvertise. Please read the 1st link for the rules and 2nd link is the link for the actual posting.
https://www.aomci.org/cgi-bin/yabb2/YaBB.pl?num=1326461963
https://www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=Webvertize
Here is a bunch of links to online salvage yards around the United States.
https://www.sea-way.com
https://www.outboard-parts.com
https://www.laingsoutboards.com
https://www.tcoutboard.com
https://www.fairwindsmarina.com
https://www.salvagemarine.com
https://www.marinepartsoutlet.com
https://www.outboardexchange.com
https://www.Superior Marine (800-338-9281)
https://www.budgetboats.net
https://www.americanoutboard.com
https://www.piratemarinesalvage.com
https://www.trixieslanding.com
https://www.mmmarinesalvage.com
Good luck!! :) :) :)
Hey, those little 3hp Evinrude Johnson motors are great!!!
I have 4 of those!!! One I am currently rebuilding!
1957 Evinrude 3hp (80 psi upper and lower)
1958 Evinrude 3hp (78psi upper and 76psi lower)
1959 Evinrude 3hp (75psi upper and 75psi lower)
1965 Evinrude 3hp (rebuilding) ( 0 psi upper and 68psi lower) had blown head gasket!
If, you can tolerate a little advice about those motors, then I have some. :LOL2:
Originally, those little motors had bushing connecting the wrist pins and connection rods to the crankshaft. They continued the same set up until 1968. The reason I am bringing this up is that running the motor with a fuel to oil 50:1 ratio will short life that motor. I know that is the "manufacturer" recommendation.
The original fuel to oil mix ratio was 16:1. The motors with the bushing needed a lot of oil to prevent wear and protect the bushings, crankshaft, wrist pins, and cylinders and rings. A lot of the older motors still have good compression despite having years more of run time on them.
The manufacturer went to 24:1 to around 1960 to 1963. Then went to 50:1 1964 and there after. They did this because the rest of the larger motors already went to needle bearings and thus need much less lubrication. Also improvements of the 2 cycle oil was an added bonus as well. Prior to the 2 cycle oil improvement regular SAE 30wt non detergent motor oil was used in all motors.
The reason I am going through all this song and dance is to let you know that 50:1 fuel oil ratio is not sufficient oil to protect that motor from wear and tear. You motor still has bushings!!
I would recommend using a minimum fuel to oil ratio of 24:1. I use 16:1 in all mine (3hp motors Evinrude Johnson motors, but that is a personal choice because that is what they original call for and the added oil helps protect my motors). The extra oil will not harm your motor!! Seafoam can take care of any extra deposits. :) :)
The 24:1 fuel oil ratio will give your 1965 Evinrude added protection from wear. You stated that the mechanic stated that you had 60psi compression in your upper and lower cylinder. That is low minimum for your motor. It shows that a lot wear has taking place already with using 50:1 ratio.
Try adding a 1 or 2 ounces of Seafoam (can be found at most auto stores) to each gallon of fuel oil mix. It will help decarbon your the inside of your motor's rings, cylinders, exhaust ports..etc.
At first it will smoke at bit more, but that is because the Seafoam will be removing the carbon in the engine and then after about a tank or two it will run will a lot less smoke, like normal. Continue the Seafoam from there on and you will help keep your motor clean and prevent gumming up. The Seafoam is very safe for your motor and been around for about 40 or 50 years. Hopefully your lower compression is from semi stuck rings and preventing good compression. Hopefully the Seafoam will removed the excess carbon/coking and free up the rings and you will get better compression with improved running.
I have several buddies that are semi retired mechanics on the AOMCI(Antique Outboard Motor Club Inc) forum that will testify, even with the great advancements and improvements of 2 cycle marine motor oil (TW-C3) that 50:1 fuel ratio is not enough oil to lubricate and protect the 3hp Evinrude Johnson motors from 1968 and prior!!
24:1 fuel oil ratio is 5.3 oz of oil per gallon (but who is going to measure 5.3 ounce....just put 6 ounce and been done 8) ). Then added your 2 ounces of Seafoam and mix it up and your golden!!
Well, I think I have talked your ear off!!! I'm glad you got that little beauty running again!!! Oh, don't for get to check and replace your lower unit oil (any marine grade 80wt to 90wt gear oil will do )and replace your motor with a good impeller (water pump).
Here is a parts diagram for your motor!!!
https://www.marineengine.com/parts/vintage-evinrude-johnson/380570/catalog.html?https://www.marineengine.com/parts/vintage-evinrude-johnson/380570/38057000001.htm
Give a yell if you need help!!
24:1 fuel oil ratio is 5.3 oz of oil per one gallon 87 octane gas (but who is going to measure 5.3 ounce....just put 6 ounce and been done 8) ). Then added your 2 ounces of Seafoam and mix it up and your golden!!
Thanks Gramps50 and cajuncook1,
Yes sir, a lot of good info you guys posted. I do appreciate the help. I already ordered some parts for my 3hp.
Cajuncook1, When I got my motor, the ol' boy told me about the 24 to one ratio fuel/oil mix. I got my fuel parts from Bobby and he is
putting me on the waiting list for the others. He sounds like a good men to deal with. I need to set down right now and write him out a
check so I can get those parts as soon as possible. I want to try it out on my canoe. It worked fair on my friends 12' jon boat.
Don
