I keep getting water in my driver side trailer bearings. I replaced bearings and seals with Timken bearings back in September because of the same issue. I popped the dust cap off yesterday to find a mess of water and rust (worse than in September). Passenger side is fine. The inner bearing is shot which leads me to believe its a grease seal issue. Just trying to figure out if the water is getting in between the seal and the hub or the seal and the spindle. The spindle is in great shape except for the area where the grease seal would seat. It has some rust and is a little rough. I took some steel wool and some very fine wet/dry sandpaper to it when I replaced the bearings to smooth it out. The hub has a few nicks in the area where the grease seal seats as well. Just need to figure out if I need to replace my hub, spindle or both? Can a spindle be replaced? Or would it be best to get a whole new axle if the spindle is shot?
Here are some pics. Let me know what you guys think.
Grease seal area of spindle.
You can see the rest of the spindle is in great shape.
Hub. You can see the one nick where the grease seal would seat. There are probably 4-5 nicks around the grease seal area. You can also see the inner race is shot. These were replaced back in September and look much worse now than the ones I replaced.
