Stumpalump said:T-Tops are only $255 to $309 with free shipping unless you want 1 1/2" aluminum that is strong enough to mount radios, lights, antenna and rod holders. https://www.ebay.com/bhp/boat-t-topShaugh said:It's surprising that somebody in the boat business hasn't picked up on the idea for marketing an affordable T top system. It's as steady as you want to make it. There's fittings for 1.5" conduit too... You could probably make a single upright with that and be able to go 40 mph.. As long as you reinforce the footpads sufficiently there should be no limit to the possibilities.
I live in AZ and we get constant year round sun. I wear a full brim Tilly hat and long sleeves shits even if it's 113 degrees. Exposed skin is too hot but you can hang out all day in the sun if it's not hitting your skin. Buy the good ones at REI, Eddie Bowers, Cabellas ect. Keul brand of pants from REI are what I use for long pants at the sand dunes or long days in the sun. All are pricy but I will actually wear it. The bass tards here were ski masks to cover their whole heads. The aresol sun screen is only expensive until you use it. Cream is grease. Aresol dries to nothing. I only use it on my legs with shorts. Feet get covered by these. https://www.astraldesigns.com/shop/footwear/unisex/rassler-unisex Most other water shoes are a plastic gimmick. "There is no such thing as bad weather only bad gear". Sun gear is as important as having Gortex. But yes there are fools that don't buy it either. Good...They stay home.
+1 on the long sleeves. Contrary to what common sense might tell you, wearing long sleeves in the hot sun is actually more comfortable, especially with the high tech fabrics. I have UPF rated long sleeve shirts in the Columbia brand as well as others. They are pricey as you say, but my kids and the boss know I'm happy to see these on my B-day (it pays to have a bunch of grown kids). I use tons of sun screen. One warning about the aerosol sun screen. Keep the overspray away from your fish finder screen and other glossy surfaces. Tough to remove when it dries.
