Swim ladder
llbaker2
Swim ladder
Post by llbaker2 » 15 Jul 2018, 10:31
I just added a swim ladder to my 1752 Standard Blazer. I had total replacements on my left hip and right knee a few yrs ago. My balance is not what it was pre-surguries. Im 60+ and not in the best of shape. Was concerned about falling overboard and then being able to get back in the boat after a swim. Got a Garelick/EEz-In 06131:01 Telescoping Hook Ladder. Looks like nice ladder but standoffs were to short for my boat. The ladder was at to much of an angle back under boat making it hard to use. Made a couple extensions so ladder would be near vertical and easier to use. Seem to have worked out well. Used a couple pieces of 7/8" oak dowel (cut to 9 inch lengths) and a couple 7/8" rubber cane tips. Only problem that I've noticed so far is that I cant fold both standoffs in toward center any more. Can still fold one but not the other which causes a bit of a storage issue. Have yet to test in water but climbed into boat in shop and worked well. Think I can use on side and/or transom. Not sure how far boat will lean when trying to enter from the side. Can stand on side edge with no problem so think it will be fine. Still need to test this. May need to add a couple screws thru standoffs and into dowel to keep them in place or may add a couple small wire retainer cables and insert/remove extensions with each use. Will just have to experiment to see how it works out.
Riverdog
Swim ladder
Post by Riverdog » 16 Dec 2018, 13:03
httpss://thebassboatladder.com/
Here's one I thought was interesting. Probably not right for your situation though. Would be nice for a minimalist or emergency ladder.
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
DaleH
Swim ladder
Post by DaleH » 16 Dec 2018, 13:14
Here’s another option, for a permanent/secure mount, with no holes below the waterline either:
httpss://www.forum.tinboats.net/viewtopi ... lit=Ladder
#1) 1st tin rebuild, 18' Lund http://forum.tinboats.net/viewtopic.php?f=21&t=36583
#2) 25' Parker refurb from EMPTY hull http://www.classicparker.com/phpBB3/vie ... p?f=15&t=6
#3) 16' V-tin rebuild http://forum.tinboats.net/viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins http://forum.tinboats.net/viewtopic.php?f=3&t=37548
