MRichardson
How do you guys go about sealing the thru-hull holes for the transom? I just re-installed a transom, squirted 5200 into the holes, screwed the bolt thru the hole and put on the washers/nuts.. Still have some leaks. Should I have gone around each hole with a bead of 5200 first? Is there a trick that works better than that?
