bow_hunter8
I have a 1995 25 hp evinrude console steer that acts like it has a rev limiter sometime when i put it into gear, i have to wiggle the handle throttle control back and forth then it runs great, any ideas?? Thanks
[url=https://www.tinboats.net/forum/viewtopic.php?p=326632#p326632 said:bow_hunter8 » Today, 16:43[/url]"]Well its not that it wont rev all the way its like some safety deal, it will rev up rev down rev up rev down real fast, it runs flawlessly other than that, is there a safety switch or somethin that im not finding?? Its most deffinately some kind of electric or mech rev limiting thing,
[url=https://www.tinboats.net/forum/viewtopic.php?p=336739#p336739 said:bow_hunter8 » Tue Dec 17, 2013 8:12 pm[/url]"]Thanks i will try that, it seems to me like it is a overheat safety, or something, it only does it after i run wot for 10 miles or a good ways anyhow, but it dont do it untill i come off of wot slow to just a couple mph and then try to go back to wot. Let it idle around for a bit then it comes right out of it. I will post my results as soon as we get open water again!! Thanks again
[url=https://www.tinboats.net/forum/viewtopic.php?p=336777#p336777 said:MDCrappie » Yesterday, 16:30[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=336739#p336739 said:bow_hunter8 » Tue Dec 17, 2013 8:12 pm[/url]"]Thanks i will try that, it seems to me like it is a overheat safety, or something, it only does it after i run wot for 10 miles or a good ways anyhow, but it dont do it untill i come off of wot slow to just a couple mph and then try to go back to wot. Let it idle around for a bit then it comes right out of it. I will post my results as soon as we get open water again!! Thanks again
If it was the SLOW system it would shut you down as soon at it activates, it wouldn't "wait" till you come off plane.
[url=https://www.tinboats.net/forum/viewtopic.php?p=336835#p336835 said:Pappy » Thu Dec 19, 2013 11:06 am[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=336777#p336777 said:MDCrappie » Yesterday, 16:30[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=336739#p336739 said:bow_hunter8 » Tue Dec 17, 2013 8:12 pm[/url]"]Thanks i will try that, it seems to me like it is a overheat safety, or something, it only does it after i run wot for 10 miles or a good ways anyhow, but it dont do it untill i come off of wot slow to just a couple mph and then try to go back to wot. Let it idle around for a bit then it comes right out of it. I will post my results as soon as we get open water again!! Thanks again
Read what he wrote before making a blanket statement.
He comes off plane to around Idle then tries to go back to WOT. The SLOW system will indeed come into play at anything above 2500RPM. Also the system will not "shut you down" but will limit RPM to around 2500.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337618#p337618 said:bow_hunter8 » Wed Jan 01, 2014 1:41 pm[/url]"]That is exactly what im saying it does, start throttling up get maybe half throttle and bam! Cuts off like no spark, idles back down runs fine.. So why would it be overheating? It pumps a ton of water
