The Sea Sprite I purchased from Harrisburg, Pa International Airport rescue boat. It was painted bright yellow inside and out. They used a wire wheel to ruff the aluminum for paint. When I stripped the yellow paint off I discovered not only wire wheel marks in random patterns, but very bad oxidation as well. I used 2000 grit and Mothers Mag and Aluminum. But it wasn't a uniform finish. Some shiny spots and some brushed aluminum. That's what I have now. So I'll need to sand it all down once again for a more uniform and shiny look.
I used Zip Strip marine stripper (around $15 a can) it did great. I just finished it a few days ago. I live in Northeast, Pa when I stripped it, the temperature was in the low 40 degrees ( I did it outside). It didn't effect the process at all. Some suggested Aircraft Stripper at $69 a can. I did it with 2 quarts of Zip Strip.
I'll send photos soon.
Thanks for all your responses.
