Have just recently been having issues with what I'm guessing is cavitation/slippage as my boat starts to get on plane. Never had this issue before so trying to figure out what the problem is. The best way for me to describe it is the motor "vibrates" as it is trying to get up on plane and feels like it losses torque. Similar feeling as if your truck tires slip on a wet road. Definitely don't think its a motor issue as the motor itself is running fine. If I let off the throttle a bit it goes away and I can slowly open her up and all is good. My buddy hit a rock a few weeks ago while we were duck hunting smashing up the drain hole. We opened the drain hole back up and had to do some welding to the outside of the drain hole. I also threw some 5200 around the welds. So the area around the drain hole is definitely not in the best shape. I'm thinking that is letting bad/aerated water back to the pump? Don't have a picture right now of the area, but everything was fine with the boat/motor until after we fixed the drain hole. I have a video from yesterday of it doing this that I'll try to upload, if I can figure out my computers editing software.
This is a '94 Johnson 50/35 with about 35 hours on it after a complete rebuild last summer. It is on a Tracker Sportsman 1648. Has a new foot and 3-blade stainless impeller that have been working great up until now. Actually got up on plane much better than my old aluminum impeller did. Motor is also running close to 5500 RPM's at WOT. Was always a little over 5300 before. Have never had issues with cavitation/slippage until after we fixed the drain hole. The drain hole sits dead center of the jet foot, so if it's messed up I guess that makes sense that it would send bad water back to the pump. If that is the case, whats the best fix? Thinking of smashing the drain hole closed, welding it up and smoothing the bottom of the hull right in front of the jet foot. Been wanting to put a drain plug on either side of the transom anyway for easier access.
