Cleaning carpet
batman
Newport News Va.
My boat's carpet could use a bit of cleaning.What method do you guys use?
I've heard that a handheld wand at the car wash works good..
thanks
Hook your garden hose up to your hot water heater outlet and mix a scoop of Tide detergent in a five gallon bucket of hot water. Tilt the trailer so the water will drain and open the hull drain. Use hot water and Tide mix with a stiff bristle brush then wash the hull out a couple times.
Best part is with the hot water you don't mind doing it on a cool day. =D>
Jamie
The car wash works well but you have to be careful or you will pull the carpet loose from the glue.
When we still had the big boat, my wife would take out her carpet shampooer out and use it.... I used it on the my lil tin to get out some blood and grime a while back..... worked good.
