Disconnect battery before charging?
aeviaanah
Stanislaus County, CA
I have a deep cycle battery that is hooked up to bilge pump and trolling motor. I also have a starting battery that is hooked up to motor and fish finder is it ok to charge while still connected to these items?
Yeah, you can charge with these items connected.
The only thing I disconnect is the trolling motor, but that's only because I charge through the trolling motor plug.
As long as the device has a off switch and it doesn't allow power to the device, it will be OK. The only device I have that doesn't, is my MG Wireless Trolling motor. As long as it is plugged in, it is on and awaiting a command. The manual says to unplug it while charging.
