sbritt23
Alright so i was going to buy a switch panel but i was like you know what ill just make one. I get a sense of accomplishment when i make my own stuff. So im going with some marine toggle switches with rubber boots since this boat will be in salt water and im doing a pvc 4x4x2 junction box that will be mounted under my legs on the bench. i will be having 3 switches and plenty of room for others if needed in the future. I will be powering Nav lights, bilge pump, Led gunnel lights. Also will be adding a cig. lighter plug. So my big question here is when i get all this and run my wire back to my battery do i need to put a fuse on each and every single thing or do they make something where i can run 1 power wire to something and then hook the wires up to it with fuses already installed. I was thinking a bus or something but i wasnt sure of the exact product i needed. any help or pictures would be appreciated
