62kodiak
I recently purchased a 28hp 1962 evinrude speedtwin and I figured that I should change the water pump impeller and spark plugs. When I took it apart i noticed the lower crank seals were bad. I am trying to get the powerhead off of the rest of the engine but with no luck. I have broke almost every bolt that I have touched and even though all the bolts are either removed or the heads are broke off the powerhead doesn't seem to want to come off. Am I missing something?
