jaskbunc said:How do I get jiffy luber to work with zerk fitting?
fender66 said:jaskbunc said:How do I get jiffy luber to work with zerk fitting?
What's jiffy luber?
gillhunter said:fender66 said:jaskbunc said:How do I get jiffy luber to work with zerk fitting?
What's jiffy luber?
+1
Scottinva said:Just press it against the zerk fitting and hold pressure against it and grease will go in. I believe that is what outboard jets recommends instead of a grease gun.
HOG WILD said:I use a light duty hydro grease gun. I have given it a few pumps with out it attatched to a zerk fitting. One pump pushes out a minimal amount of grease. I really find a hard time believing that If I pump slowly and take my time that I would blow out the seals. Also considering that the hose is a release valve for when it gets to full. Am I missing something?
donmac said:How do you know when you have pumped in enough grease?
I bought a used boat a couple of days ago. The former owner used the 'jiffy luber' to grease it right before we went on the test ride - but I did not see him do it. He showed it to me when he was done.
He told me he greased it every time he used it. I have not tried it myself yet. Is there someplace that grease will come out when you have pumped in enough?
EVERY TIME you run the boat & come back in for the day, freshwater AND especially in saltwater, use the recommended low pressure grease gun & lube the impeller shaft's bearings that are located under the water pump. This is accomplished by removing the rubber hose/grease nozzle that is snapped onto the Zerk fitting close by. Some of the early units do not have this rubber tube but do have a 1/4" stainless round headed relief bolt that needs to be removed. Do not use a regular hand pump grease gun , but the tube type gun that has the Lubriplate tube attached for less pressure. Pump a couple of pumps, or until the Lubriplate grease starts to come out of the nozzle or hole. Stop, wipe off the excess & replace the nozzle. This nozzle is merely a cap covering the Zerk fitting. On the opposite side of the unit as the grease fitting is a small hole in the base that you may never see, that is also a relief hole for the excess grease to be pushed out. It is imperative that you grease the unit each time it is used to be sure that IF any water has gotten inside, that the new grease will force the water out & not allow this water to stay trapped inside giving the chance of rust to start in the bearings when the boat & motor may set idle for a while.
