1987 Nissan NS15-B
15HP
2-stroke
Attached is a pic of my lower unit gear lube which shouldn't look like thin mustard.
So, I pulled the unit . . .
1) submerged the unit in water up to the bottom of the water pump housing
2) removed the shift rod
3) applied 10-15psi compressed air to the shift rod port
Results . . . NO BUBBLES anywhere.
I'm stumped . . . any ideas on how the water is getting into the gearcase?
Have never pressure tested a lower unit so I'm not even sure this is a good method . . . it just seemed reasonable?
15HP
2-stroke
