rivet supply
fowlmood77
Williamston, SC
I remember seeing someone suggesting a company online that I can get solid rivets from. Unfortunately I cannot remember the site.
Yep.They are cheapest at Aircraft Spruce,buy'em by the pound.If you're using the dome head rivets get a bucking bar.It helps.If you have flat or counter sunk rivets just use a flat faced shop hammer.
Yep. Thats the place. If you need them quick, and you have a Grainger close by, you can get some there. However, being where I live, I usually get my Aircraft Spruce orders in 12 - 20 hours, unless something is backordered.
While you are at it, get them to throw a catalog in with your order. That thing is HUGE, and contains some of the most unique fasteners that you will ever see.
it's amazing how much stuff Aircraft Spruce has that can be used as marine items as well as aircraft items. They are the only place I found (after about 3 weeks of constant searching) for the fuel selector valve in the size I wanted. It was actually designed to select from 2 tanks to 1 engine, I just connected the hoses the other way and have one tank feed 2 motors.
fowlmood77 said:
They would be cheaper by the pound, but I don't need near that many. :lol:
buy you a pond and list what you dont use on here for sale there are always people needing rivets .just a ideal
Found the site I was looking for
https://www.mcmaster.com/
And $1 cheaper than Grainger to boot
Also remember seeing these once and may buy a few. They might come in handy one day
https://fasteningconcepts.com/Merchant2/graphics/00000001/klikriv.jpg
They are rivet nuts. If you haven't heard of them, they are used for most applications where strong threads are required for blind applications. They are installed using a spin technique and tooling. Rivet Nuts provide an internal thread into thin sheet material and at the same time they can also function as a blind fastener to join two materials together.
A homemade tool for "setting" them can be found here.
https://www.fjr1300.info/howto/rivnut-tool.html
I am thinking they would make a slick way for attaching rod holders :lol:
Rivnuts are common in aircraft and automobiles.They're used to hold the doors on my car and bolt the head lights in.I'm sure if I payed attention I'd see more of them.After there painted you can hardly see the ones the factory uses.
Go back to my project thread, and see what my wiring chase is held down with......
On second thought. I don't remember putting that in there. I might need to add that.
Ordered from Mcmaster the morning of the 20th and had them by afternoon on the 21st. Didn't realize they were out of Atlanta, but I couldn't have driven the two hours there and two hours back for less than the standard shipping of $5 and some change. Very pleased =D>
