Charger25
Fellas, got a stupid question. Which gasket failure will most likely allow water to get into BOTH pistons?
getting milky oil on both plugs on the 9.9
I was thinking that,but its both plugs and compression is goodhuntinfool said:My guess is the head gasket.
Pappy said:Do a compression check before diving in.
A milky substance in that area can also be as simple as an engine running too cold. Specially this time of year!
KMixson said:How long has it set since the last time it was run? If it has not run in a while there may have been some condensation inside the motor that is just getting sent to the cylinders. I have some trucks where I work that have a milky looking substance that builds up in the dipstick tubes because they are not run enough.
KMixson said:I hate to say it but you may have a crack. Cracks can be very hard to find sometimes depending on where they are located and how large they are. If you are sure the gaskets were installed correctly when you installed them the first time I would start to suspect a crack. You may have to have it magnafluxed to find the crack if it is cracked.
perchjerker said:make sure you dont have a cracked cylinder wall
I had a Chrysler 105 hp many years ago with one.
It ran fine, compression was fine but had the same problem. The crack was below the combustion chamber area
just another thing to check for
