Maggiesmaster
- Joined
- Jul 8, 2008
- Messages
- 25
- Reaction score
- 0
I'm buying a 16 ft. flatbottom boat & want to wire my 40 lb. thrust bow-mount Minn-Kota trolling motor. The battery will be in the back, and the wire will run to the bow. What size wire will I need for this? Will I need a circuit breaker on it; if so, why?? I plan on running a separate wire set from the same battery to the depth finder mounted on the trolling motor. Could I also use the trolling motor wire for this, and attach a separate wire near the bow?
Thanks for the help!
