msoverto
- Joined
- Aug 6, 2013
- Messages
- 7
- Reaction score
- 0
Quick question: I am in the process of building a modified jon boat (basically adding a platform to the boat), and recently purchased a 55 lb thrust bow mounted terrova. I also purchased a minn kota power center which I will be powering the trolling motor with from under the casting deck. I noticed that at the end of the trolling motor wires, that the terminal rings are small in diameter (I believe too small to fit on a battery post). I also purchased a trolling motor receptacle which I plan to install on the platform for easy connections.
my question is for how to appropriately set this up. Is it as simple as taking the trolling motor wire and cutting it at the appropriate length to the receptacle plug in the deck and then taking the remaining wire and attaching it to the other end of the receptacle socket under the deck and then cutting off the smaller circular terminal rings and attaching larger terminal rings which will then connect to the minn kota power center?
just trying to figure out the proper way to wire this. Any help would be greatly appreciated
