jigngrub
I'm helping a friend modernize his outdated Lone Star closed bow utility runabout. It's a deep semi-V, 16' long with a 76" beam:
The first order of business was to cut out the covered bow that wastes lots of good deck and storage space:
Then there's the old timey box seat bases:
Gone:
The start of the front deck framing:
We're using .063 ga. 1-1/2" extruded aluminum angle.
We're also using 3/4" tongue and groove subflooring for the decking. This board has no core voids and a 50 yr. warranty against delamination. We're fairing and sealing the decking with epoxy resin and SM fairing compound:
After the first coat of resin we fair (fill) the rough surface with the compound to smooth it out:
After a2 coats of fairing compound and 2 coats of resin we get this:
We're also installing lots of floatation foam:
We're using both polystyrene sheet foam and 2 part expanding urethane foam:
There's already about 2-1/2 4'x8'x2" sheets of polystyrene and 2 cubic feet of expanding urethane foam in just the bow area.
Here's the front deck framing completed:
... and with the storage divider and support bulkheads installed:
I blacked out the hatch openings and the red dot will be the pedestal seat base for clarity:
Still lots of work to do with installing the main deck, steering console and the rear deck, I'll update as we proceed.
Gone:
