riverrunner5891
I am wanting to put a new stereo in the boat. The one in there now leaves some major things to be desired, only having 2 6 1/2 in clarion speakers (one that is blown). What I am wanting to do is to replaced those two speakers with two new MBQuart 6 1/2" speakers, along with adding four MBQuart 6x9s and an MBQuart 350watt amplifier. I will also be replacing the existing head unit with the Clarion 109 Marine head unit. I currently have two batteries in the boat, one for the main power and one for the trolling motor. They are looped together so that they charge at the same time, as well as if one battery gets low it can feed from the other battery. My biggest question is: Should I leave them looped together, seperate them to ensure the radio cannot run the main battery to start the boat dead, or put them on a battery switch of some sort so that if need be I can still switch from one battery to both batteries (in the event my main battery would go dead I can still start the motor)? Also, I don't think that stereo would be too large of a drain on the battery in the first place, but I suppose to be safe it would be wise to possibly let the stereo play for several hours and see how much it drains the battery while on land rather than find out later? I just don't want to be way up/down stream and kill my battery with the stereo. Thanks in advance for any help!
