crashwood
I have a Minn Kota Freshwater Bow-Mount PowerDrive V2 Trolling Motor, PowerDrive Foot Pedal Control, 24 Volts, 70 lbs. Max Thrust, 54" Shaft Length, Variable Speed Control, 42 Max. Amp Draw, Weedless Wedge 2 (MKP-32) Prop, Deploy-Assist Lever, Digital Maximizer, Push-To-Test Battery Meter, Propeller, Indestructible Composite Shaft, • PowerDrive Foot Pedal Control
Took motor off the boat that I sold to put on a boat that I was buying but the boat that I bought came with a trolling motor a smaller one so I don't need this one, runs excellent $400.00 FIRM
• 24 Volts
• 70 lbs. Max Thrust
• 54" Shaft Length
• Variable Speed Control
• 42 Max. Amp Draw
• Weedless Wedge 2 (MKP-32) Prop
• Deploy-Assist Lever
• Digital Maximizer
• Push-To-Test Battery Meter
• Propeller
• Indestructible Composite Shaft
• 24 Volts
• 54" Shaft Length
• 42 Max. Amp Draw
• Digital Maximizer
• Propeller
