Material Links for your conversion
Bugpac
Lawrenceville Georgia
All links good, enough for tonight. Finish the rest later.
Post up your special materials links and well make a complete list. Ill edit them and add them to this post.
Steelflex https://www.fascoepoxies.com/
Bassboy1:
Aluminum continuous hinges for hatches. 1/2 the price as the brass plated steel (which will start rusting) from Lowes/Home Depot etc. 1/2 price more than covers shipping, especially on the 3 ft. lengths. Excellent service from these guys as well.
https://www.aircraftspruce.com/catalog/mepages/pianohinge.php
Dearl:
Camo stencils, good pricing and fast shipping.
https://www.reelfootcustomcamo.com/
Rellis1962:
Marine electrical wire. Good prices, fast service, excellent product.
https://www.tinnedmarinewire.com
Perchin:
Alluminum Diamond Plate. You get free shipping with these guys...nice!!! Decent Price too. :wink:
https://www.quickshipmetals.com/diamond-plate/aluminum-diamond-plate.html
Russ010:
A lot of marine electrical supplies - wire, switches, bus bars, etc - https://www.genuinedealz.com
Slick Bunk Boards - Ultimate Bunk Boards https://www.ultimatebunkboards.com
Mojo:
Multitude of Rugged plastic boat components. Thru hull fittings, drains, vents, yada yada yada.
https://www.marineeast.com/a_hme/hme_hme.asp
Perchin:
If its made, it can be found here!!!! (hardware that is) quick shipping too! I paid for rivets, and recieved them two days later.
https://www.mcmaster.com
Outdoorsman:
https://www.kendormarine.com/
Bandgeek1263:
I'f you're making a bimini top or using polyester webbing for deck hatch handles:
https://www.voguefabricsstore.com/store/home.php
2x2 Framing supplies (Strong Ties):
https://www.strongtie.com/products/connectors/rtc-fwh.asp
Bear7625:
Bought my steering system from them. Beat everyones prices.
https://www.lowcostboatingstore.com/
Bear7625:
This is where I buy all my stainless steel screws and alluminum rivets. They have stores all over the country, but they don't do a lot of expenceive advertising.
https://www.fastenal.com/web/home.ex
Bear7625:
This site looks like it has good prices.
https://boatcarpetbuys.com
Henry Hefner:
Just bought wheel bearing kits to redo my tilt-Dilly single axle trailer from etrailer.com. All bearings, races, seals, and cotter pins shipped to my house for under $25. Ordered it Sunday night and received an email that it shipped on Memorial Day!
https://www.etrailer.com/
Mrhitman007:
Amazing carpet for the price... purchased the 6' x 20' and wish I got the 8'6" x 25' for my 14.5' build. Goes quick with all of the cuts and what not.
https://www.sportsmansguide.com/net/cb/cb.aspx?a=650798
Hanr3:
buyer beware!
However there are some good vendors who use ebay as thier store front.
https://www.ebay.com
One Legged Josh:
You might think I'm joking, But by far the best price on my boat seats and 97 cent shipping to my door. They have 10x the stuff online-only vs. the stock in the store...
https://www.walmart.com/
Bullet Pusher:
Here is a link to high-density polyurethane foam core composite board, which is a lighter weight substitute of marine grade plywood. Injected foam between two sheets of fiberglass. 4x8 sheet of 3/4" weighs 49# compared to 65# plywood. Expensive at $180 a sheet, but impervious to gas, oil, water and very strong, light weight, and rigid. Just needs to be painted to protect from UV light. Cuts with standard wood blades. Located in Grand Prairie, TX. (Between Dallas and Fort Worth)
They also do really thick custom transom pieces as well.
https://www.kayco-composites.com/index.html
Azslabber:
I just ordered a 12 oz. can of the "Lab Metal" to repair the dings and such on my flat bottom project that I have going on right now.
https://www.net4sale.com/Shop/pc/home.asp
Airal:
I'm giving serious consideration to this stuff for my deck: https://www.lockdry.com/lockdrydemo.htm
Anybody had experience with it? Looks ideal for an aluminum boat floor.
Azslabber:
Here are some pretty cool floor matting for aluminum boats.A little expensive but very nice.
https://styx-river.com/products/?catego ... ry=6&id=31
Hooky1420:
Has all kinds of parts for your towing vehicle. I bought my tow hitch, receiver, ball, and light harness from them. Cheap prices, and fast delivery.
https://www.suspensionconnection.com
Azslabber:
I found these guys and am going to order some when I get my center bench cut out and closed off in the very near future.Take a look.
https://www.aeromarineproducts.com/
Seasprite:
I purchased my used 18 foot Jon boat and restoring this winter. Since it was a used boat it has seen its share of beaching. All my other boats are semi V's with nice thick keels and I wasn't concerned with beaching. The river I fish has poor launches at best (no docks) so you have to beach each time you go out. I'm a guide on the river so I'm always launching and removing. The 18 footer has 4 keels which are pretty worn. I searched the web for keel guards. A few companies wouldn't recommend using their product on a Jon boat. Until I found Keel Shield https://www.keelshield.com KS Marine Product
These people went out of their way to accommodate me. They sent me a sample of keel guards, and easy to follow instructions, great color selection, and its a life time guarantee. They also make skeg guards, bow guards. I highly recommend them, they stand behind their product!
Reedjj:
I came across this solar battery charger today looking for stuff for my boat.
Not sure if anyone has tried one of these, but it might be nice to have on those long days on the water when your trolling motor is getting a lot of use. You could just connect it to your batt. and as long as the sun is shining you are getting a little bit of a charge and not killing your battery!
https://www.harborfreight.com/automotive-motorcycle/battery/5-watt-solar-battery-charger-41144.html
Bugpac
I don't have no links to post just wanted to say this is a great idea.
www.tinnedmarinewire.com Marine electrical wire. Good prices, fast service, excellent product.
https://www.mcmaster.com/#
Great place - a buddy of mine just got hired by corporate, maybe I can get myself a discount :twisted:
www.ebay.com
buyer beware!
