NCtoGAboater
Alright, well I got this little boat off of CL for 140 bucks. It is a weird boat, as far as the interior. There are no ribs that run from side to side, except for two, which the previous owner capped with aluminium angle. From what I can gather, this boat was pieced together or is homemade from a kit or something.
Anyway, it was right red when I got it, so i stipped the bright red off as best as I could, which left the old chalky blue paint. It was adhered pretty good, so i just sanded the exterior with some 60-80 grit paper (old fashion elbow grease) and left as much of the old paint as possible, so I didn't have bare aluminum. I primed the boat with rustoleum professional primer and then painted with professional enamel.
So my plan is to create a deck in the front of the boat, keeping it as low as possible, from about where the old front seat was to the front, and attaching a trolling motor to the front of the bow. Then place some plywood over those two pieces of angle to make a smooth deck on the bottom, and just building a little cubby area in the rear of the boat for the gas tank, storage, etc....
I would like to building some rod holder boxes along the side of the boat as well. As far as seating, I am just going to have the pedestal seat on the front deck, a seat on a pedestal in the rear to control the motor, and another removable seat in the middle of the boat, for the second passenger while we are underway. I know its kind of confusing trying to imagine it, and I am planning on drawing out a rough plan, which I will post.
I plan on using aluminum angle/channel as I see fit to building the framing. I guess the first thing I wanted to ask is how do I go about framing out the front deck I want to add. With no rib supports along the bottom of the boat, how am I supposed to attach the aluminum framing to the boat. Look forward to continued posts here, as I build my new boat.
