1983 Starcraft semi V-16 Project
bterry
So I decided to start my boat resurrection project last week. This is what I started with...nothing like truck bed liner on the bottom of an aluminum boat!IMG_20130714_113758.jpg This is after about 20 hours of sanding/grinding the truck bed liner off and chemical stripping the rest.IMG_20130721_205113.jpgI used Rust-Oleum Professional Aluminum Primer and Majic tractor and truck oil based enamel. I mixed the paint with a hardener and reducer and sprayed it on with an electric Grayco sprayer. Very happy with the results!IMG_20130721_205100.jpg The following are links to products I felt were worthy of sharing
Paint Stripper: https://www.lowes.com/pd_6058-1168-0203-30-02_0__?productId=3370378&Ntt=paint+stripper&pl=1&currentURL=%3FNtt%3Dpaint%2Bstripper&facetInfo=
Aluminum Primer: https://www.homedepot.com/p/Rust-Oleum-Professional-15-oz-Professional-Aluminum-Aerosol-Primer-254170/202531910#.Ue_arY3VB8E
Oil Based Enamel Paint: https://www.tractorsupply.com/en/store/majicreg%3B-all-purpose-enamel-oil-base-gloss-1-qt-ford-blue
Clear Coat: https://www.tractorsupply.com/en/store/majicreg%3B-clear-coat-high-gloss-lacquer-1-qt-clear
Hardener: https://www.tractorsupply.com/en/store/majicreg%3B-catalyst-hardener-1-2-pint
Reducer: https://www.tractorsupply.com/en/store/majicreg%3B-reducer-1-pint?cm_vc=-10005
Airless Sprayer: https://www.lowes.com/pd_333008-48690-258870_0__
Here it is last summer after the paint job and trolling motor install.
So here is an update of my nearly complete jon boat resurrection.
