9.9hp evinrude what year?
Mike Redmond
Just bought a two cycle 9.9 evinrude regular leg manual start.I was told by the seller it was a 1979...tried the INTRODUCES system but it starts in the 1980's only,,,,model no. of my motor is10924B,,can someone enlighten me on this . Thanks
Its a 79. Here's the weights of the motors.
I didnt know they had electric start on those little motors till I looked up your Size number.
1979 9.9hp Evinrude
15" shaft, manual start = 72lbs
15" shaft, elec Start = 77lbs
20" shaft, elec start = 82lbs
Mike you can access model years of most evinrudes here: https://shop.evinrude.com/ just click on model year guide top right hand of web page.
Mike Redmond said:
Thanks,but where do you go to find out what year it was...Mike
Here is a LINK to help you determine any of the pre 1979 Johnsons.
https://www.marineengine.com/manuals/johnson/
Here is a LINK to help you determine any of the pre 1979 Evinrudes.
https://www.marineengine.com/manuals/evinrude/
Johnson & Evinrude 1979-2007 outboard motor model code explanation
https://www.sschapterpsa.com/ramblings/omc_model_code.htm
Here is some very good reading for you and your motor. Enjoy!!
https://www.sschapterpsa.com/ramblings/OMC/OMC%20info.htm
Enjoy your motor (very good and dependable when serviced and maintained!!
cajuncook1
