BottomDweller
Ok guys,
Looking for a little guidance. I've got this Evinrude 1993 4 hp that needs some maintenance. First of all let me emphasize that this is the first time I have attempted to work on a motor. The motor already runs pretty good for the most part. I just want to do a little maintenance to preserve the motor and also to learn alittle. I am looking to first replace the impeller. I ordered and received the manual in the mail but I am a little overwhelmed. I finally found the part in the manual that speaks to impeller replacement. It falls under gearcase servicing. I’ve actually attached the schematics of the motor and the manual excerpt that talks about gearcase servicing. Anyway it takes me though so many steps of servicing the gearcase.
1. Does impeller replacement usually require all of these steps and requirements (see attached). It has me going through so many steps of dissembling the gearcase, driveshaft, and lower unit components, and discarding multiple things in the lower unit that does not seem to be directly tied to the impeller.
2. There are also special tools required to take this thing apart that I cannot find (ie Propeller shaft bearing remover/installer P/N 392091, Gearcase Head Seal Installer, P?N 327572, Driveshaft Bearing Remover/Installer, P/N 392092, and Driveshaft Seal Installer, P/N 327431). Where do I get these things if I truly need them. I searched the internet but no luck. Are there alternatives to these tools I could use?
3. When replacing an impeller what do you usually replace other than the impeller (all of these other things like Plate gasket, gearcase o-ring, gearcase head seals, etc. etc.?)
Thanks to any help you can provide on the attached manual excerpt for my 1993 Evinrude 4 hp and on the questions above.
