Mike Redmond
- Joined
- Feb 21, 2009
- Messages
- 157
- Reaction score
- 0
Took my new to me 1980 15hp johnson out on the lake,had brought a 2008 8hp 2 stroke yamaha as a spare,,,murphys law,if something gonna go wrong it will,,,15 hp snuffed out,so whopdidoo put the 8 on and away I went,,,,8 hp died also,rowed 3 hrs to get back to base,,my guess is I forgot to put oil in the gas for the smaller engine(musta doubled up on the 15 hp tank by error) tought it was toast but an old friend of mine who used to be a small motor mecanic stuck a big screwdriver on the flywheel and got it to rotate,it works fine in a drum at the moment but the top cyl reads 140 lbs n the lower one 130,,,wonder if it will affect it a whole lot,,,the 15 hp according to the old timer was sucking air so got a new hose and fittings from the gas tank to the engine and also a new hose from gas pump to the carburator, it runs fine also(in a drum) gonna head back to the lake in 3 to 4 days since were getting high winds and rain (sucks) my main worry is how that yammie is gonna hold up with 10lbs diff between the top and bottom,,,nyway next trip Im gonna bring 3 motors, got a little 1.2 tanaka might be slow,,, but shure beats rowing. Mikey
