Troutman3000 said:
I am not sure that I want to compromise the structural support any more than I already have....I'll figure something out which means I'll proabably just put that battery in the rear until I decide to rebuild the front deck.
How would you be compromising support? The upper deck, if bolted through the gunnels would keep the sides from moving in or out, and if you rivet the face through the sides, as I did on mine, I think you would be ADDING support. While proof-reading this reply I worry that it sounds like I am trying to tell you what to do with your boat, but I am only trying to provide you with options. After I finished mine, I found that I had to put more weight forward to get full speed out of my motor, and I wouldn't want you to give up on the idea of putting the battery up forward.
If you want to keep the front bench, is it wide enough for you to cut out a hole in the center of it that the battery would fit in, then maybe leave a hatch in the upper deck for access? I hope this makes sense to you, what I am picturing would be a battery surrounded on all sides by the existing bench seat.
