earl60446
Fished on 8/14/2014 10am to 3:30pm. Lots and lots of very small channel cats and 1 little bass. Lake is a power plant cooling lake, it is hot. In some areas it is 90 deg, did not encounter any water less than 83 deg. Would have been out there sooner but 48hp johnson would not turn over, verified solenoid and starter. Thought I would tear into remote control but could not get the 2 mounting screws loose. Decided to verify large round connector inside cowling, pulled apart looked ok. Doused it with wd40 silicone and put back together and she is turning over fine since. Lesson = low voltage requires good connections.
Tim
Tim
