Looking at the specs, the Odyssey PC 625 should have no problem turning over my outboard, 60/40 Yamaha. It only weighs 13 lbs, great weight savings. Anyone run one of these batteries?
The Specs on my motor call for 380cca, 502mca, and 124 reserve minutes. It is efi, and fires always by the second crank. Wonder why such high battery spec for this motor?
Look at the smaller batteries in Jet skis, motorcycles, etc with higher compression and similar cu/in?
https://www.odysseybatteries.com/battery/pc625.htm
