Popeye
The U.S. boating industry needs your help in preventing the EPA from allowing an increase in the amount of ethanol in gasoline.
Act Now
On March 6, 2009, a new pro-ethanol lobbying organization called Growth Energy aligned with 54 ethanol manufacturers and formally requested that the Environmental Protection Agency (EPA) allow an increase of ethanol blend levels in gasoline to 15 percent (E15). As is required by law, the EPA on April 21 published a Notice for Comment in the Federal Register, beginning a 30-day public comment period that will close May 21, 2009.
Failure to stop momentum at this stage will almost certainly cause all engine companies and their suppliers to redesign and re-engineer product lineups at a time when all of us can least afford it.
IMPORTANT FACTS:
Marine engines have not been tested with ethanol blends above E10.
Some marine engines have experienced issues using E10, and additional problems would certainly be anticipated with higher levels of ethanol blends.
Let the data tell the story! Tell the EPA to deny the E15 waiver until adequate testing has been conducted.
If you want, you can try this they have a letter already drafted at the bottom it takes only a second to submit it...
https://capwiz.com/nmma/issues/...99386
Act Now
IMPORTANT FACTS:
