eric.schimmel
- Joined
- Jul 17, 2013
- Messages
- Reaction score
- 0
Hey everyone,
I've stalked these forums for a long time but have never taken the opportunity to post. First off I'll start with a little about the boat. It's a mid 50's ouachita 1448. I recently upgraded the 7.5hp Johnson I had for an early 70's Johnson 25hp. It runs fine most of the time but I have been having an issue sometimes while running at speed. It'll get up and go, usually cruising about 22-23mph then out of no where the rpms sound like they skyrocket and it loses power and runs about 14mph. If I slow down a few times it tends to fix the issue but this last time out, it was happening more often than I would like. I took a video of it and I'm hoping you can help. Also, the carb, fuel pump and impeller have all been rebuilt. I thought it might be cavitation but the cavitation plate sits level with the bottom of the boat and it has a hydrofoil so I'm pretty sure it's not the issue.
https://youtu.be/mLiollcmu1I
Any help you could give me would be greatly appreciated. Thanks!
