A late 80s motor probably won't have the screw fitting for flushing. I don't think that was seen on motors until the 90s, and I think it was first seen on motors designed for saltwater, before it was found on the rest.
If you don't have the vents on the side, the standard "muffs" Ahab posted won't do you much good. I am assuming your Merc has the same style of water intake, that enters on the bottom of the cav plate, like a lot of the pin drive Johnnyrudes have. If so, I have always run those in a barrel, but I would like some feedback on the new style flusher for those (first one Popeye posted), as it is much easier than filling a trash can daily when I am down at the coast.
