Well just back my Johnson 15hp tiller. I had to have a fuel pump installed. I placed the motor in a tank when i got home to run it . After about 5 - 10 minutes of running with the fuel line connected, i removed the line and let the motor run out of fuel. Would the next step be to remove the two spark plugs and spray inside with fogging oil as i turn the cylinders.
