Time will tell but anything wears if you walk on it. The good thing about Tuffcoat is if it does wear all you have to do is pressure wash, clean, wipe with acetone, mask off and touch up with a roller, brush or sprayer. I have never seen Grizzly Grip. Is it a harder epoxy type coating?Bugpac said:Id do it again. Any of the coverings with rubber in them are gonna wear over time. You will see little tiny black specs over time. I have seen the stuff bass pro sells. Id stick with the griz...
