Henry Hefner
I started to repack my trailer wheel bearings, and the job snowballed. I got the bearings apart and found pitting on the races. I ordered new parts, and decided to replace the old bunk-boards. While I had the bunk-boards off, I thought I'd knock off some rust, and repaint the trailer. I wandered through Academy Sports on a lunch break, and found some trailer lights on clearance, so I replaced them, too. :shock: See where this is going? A quick lube job slowly turned into a rebuild that I had not planned at all. Oh well, I don't have to worry about the trailer for a while. :mrgreen:
Anyway, to the subject at hand, guide-ons. The ones that were on the trailer when I bought it were welded on poorly, and more than one weld had broken, so I ground the rest off and tossed it. The grinder was out anyway, getting rid of rust. I don't own an arc-welder, so I was looking for other (cheap) options to replace them. I considered going the ladder stand-off route that others are using, but my trailer is wide enough for my boat that I really didn't need much extra width. I went to look at them at my local Home Depot anyway, but the only ones they had were the heavy-duty ones, and I figured I could get cheaper than that, so I wandered around some more and came up with a plan that actually worked out for me.
$6.49 for 10' of 1" EMT conduit.
$3.58 for 10' of 1-1/4" PVC
$1.44 for 2 PVC caps
$10.45 for 4 U-bolts
I drilled holes in the trailer for the U-bolts, eye-balling the angles to get the right angle on the guides. I was afraid that the EMT might crush if I tightened the U-bolts too much, so I grabbed an old broom handle(I never throw anything away) and cut a couple of short pieces to put in the bottom of the conduit. The fit wasn't as tight as I liked, so I bushed it with pieces cut off of an old garden hose so they fit snug even before tightening down.
I cut the PVC so that is is just an inch higher than the conduit. I haven't decided whether to fasten the PVC down or not, I see little reason to. I had some reflector tape left over from making catfish jugs, so I added some to the PVC, it might help, and it can't hurt!
