kinda bored @ work, figure i will see if i can get some input from all of you experts on my next build project. so i'm mounting a longshaft 30hp evinrude on a 1436 alumacraft designed for a short shaft motor. 22" from motor mount to cavitation plate, & 16" transom, the motor needs to come up at least 5 inches based on my best guestimation
i'm going to use a sleeve style jack plate made of aluminum to reinforce & raise the height of my transom. i'm undecided about having the sleeve go full width or just wide enough to mount the motor? it's a tough decision, because the strength i gain by going full length will be offset by the additional weight. the sleeve is super thick, like 1/4" or more & heavy as hell, plus i'm already overpowering the hull by putting a 30 on there, so anything i can do to minimize stern weight will be a good thing. BUT if i go full length, it will reduce the amount of water that comes over the transom. if i go full length, i'll have to fit the sleeve around the knee brace on the transom, by cutting a slit in the sleeve.
let me know what y'all think by posting or voting. i'm wondering if i should go full width or minimum width, & whether i should angle or round the corners. also, i can wait for ban saw to do this, or i can attack it with the angle grinder :shock: here's a few pictures:
