How to convert tiller steer to a console
VAbassin said:
evansjoem said:
No haven't yet
How easy will it be do you think? I'm wanting to do the same thing your doing. Will I be able to do it like yours?
here is a mock up for you but just use a flat plate shaped like a triangle with a hole for the steering rod
Yours will be easy I think. I'm just not sure how to hook up the throttle yet
VAbassin said:
VAbassin said:
evansjoem said:
You should be able to buy a kit for yours. I am going to fabricate all of my pieces
Well I'm a welder/fabricator myself so I'm Def going to watch to see how you rig it up!
Sent from my VS990 using Tapatalk
Do you have any ideas yet for how to rig up the shift lever to the console?
i bought the standard terre flex steering system on Amazon. I have it mounted already. Comes with all the hardware and a template to use
Update. She is painted and mounted for now. I will hook up the cables when I finish the transom
Yea now that you drew that out of should be pretty easy. I'm just not sure about throttle and shifter. But it's looking good man! Loving the paint
This is the set up on my 6hp for the cables and it is wired I believe for a kill switch, I don't know what will hook up to these fitting yet? I plan on putting this on my sport canoe where I can be up front in the rivers. good luck on your build.
Well made my own bracket not pretty but works. Still need to do some trimming
Here u go kinda ugly but works good
Need to do some trimming on the motor steer bracket and found out my throttle cables are for a merc even though it says evinrude
Here it is built all my own brackets
Bad news...... two new coils installed, new power pack and new plugs. Still won't start and no spark.
I got it fixed and fished bullards Bar! Check it out!! Spotted bass close to the record!
