I haven't gone as far as cross referencing part numbers yet, but I called RIVA and Pro Tec and they both told me the best chance is finding a used one, as no one makes them anymore.
I may have to build one based on the pictures above.
What's the best way to eliminate a worn impeller/wear ring?
Excessive impeller to wear ring clearance will cause loss of top end, overall performance, and guess what else? Cavitation! Generally, acceptable range is .005" to .020" To check, remove the intake grate, and use a feeler guage to take a reading.
If it's excessive, this could be your problem.
On a typical Yamaha jet pump you have 4 parts. The wear ring, the stator, the thrust nozzle and then the steering nozzle. Some models like mine also have a reverse gate.
This is a breakdown for how to disassemble the XL1200 pump. Yours is probably similar as it's also a Yamaha.
First, remove the ride plate. This will allow access to the pump. Remove the steering nozzle. The remove 2 support bolts for the thrust nozzle. Should also be 2 more bolts that hold the wear ring assembly in place. Remove those. Then, remove the 4 long bolts that go through the pump assembly, located on the 4 corners of the thrust nozzle flange. Tap on the thrust nozzle with a rubber mallet, and wiggle it, then remove it. Now, disconnect the cooling line from the stator assembly by loosening the hose clamp.
For the stator, you'll need to use a pry bar, and pry at the designated points (small tabs on either side of the components where they mate together) The stator assembly should slide back when you pry. Once you get it to move back, then, you'll need to remove the engine coupler from the driveshaft, so you can slide the shaft out through the hull with the stator unit.
After removing the stator, then you can remove the wear ring assembly. Same procedure, use a small pry bar on the tabs, and carefully alternate from left side to right side, so as not to break the tabs.
Once you have the old wear ring assembly removed, install the new one, and re-assemble pump in reverse order. PAY PARTICULAR ATTENTION TO THE ALIGNMENT PINS THAT GO BETWEEN COMPONENTS, they are easily lost! Be sure pins are in place before assembling the components.
As for your impeller, you will need 2 BFW's (large wrenches) :mrgreen: Place one BFW on the flats of the shaft. Place the other on the nut of the impeller. (If impeller has no visible nut, but a rubber bushing, pry out the bushing. You will need a specialized impeller removal tool to remove a splined-face impeller) To remove the impeller, remember it is a LEFT-HAND THREAD, so, turn right to loosen.
You can have a worn impeller re-built by a company called Impros. They can also re-pitch it to whatever pitch you want.
