flintcreek said:
I bought a 16' Lowe Hustler with a 35 Johnson motor 1977 model not running a couple of weeks ago. Finally got around to starting to work on it this weekend, cleaned the carb. Cranked it up and it goes dead. Ok, choke it, the motor will hit a lick but not start, let the choke off and it will crank and run for 30 seconds or so. If you give it gas it will sometimes run a little longer. Again choke it, the motor will cough and try to start, let the choke off and it will start and run for a minute or so, backfire and die. I have tried 2 different fuel tanks and 2 different fuel lines. Hopefully I can get my son or someone to help me tomorrow and try to pump the bulb while it is running, to see if it is the fuel pump. Any Ideals?
Well, since this is used but new boat to you and you were aware that it is none running, there are some steps that you should take.
You will see a lot of experience guys ask about compression, spark and fuel. (They are using a systematic approach to diagnosing an engine problem or problems....in this order)
C= compression ( if your compression is low are uneven between cylinders >10% then others checks don't matter until the that is resolved) (
This is very important the previous owner could have run this motor and overheated and damaged the pistons or cylinders or the head gasket could have blown)
S= Spark (if your have problems with your ignition then you can have the cleanest carb and great fuel delivery but it will run bad or not at all) (Bad coil, spark plugs or even bad power pack assembly) **Check spark on both cylinders**
F= Fuel (if your carbs are not clean and fast/slow idle needle are not set right then it will run but like crap. If you have it set too lean then you run the risk of poor fuel/oil delivery and damage your pistons and cylinders then you run into the problem of C (poor compression from damage).
When you clean a carburetor make sure you get a kit and take out all of the core plugs, because gunk and junk and can block up the 3 tiny holes under the core plug for the slow speed idle needle.
So get a spark tester ($7)and compression gauge($12 to $14)
Here are few links for good reading and assistance.(to see the pictures on the iboats forum you can join the forum just like this one and yes it is free)
https://www.tinboats.net/forum/viewtopic.php?f=4&t=14047 (will give a link to a public library that has condense facts and manuals regarding your motor)
https://forums.iboats.com/showthread.php?t=158071 (why it won't start)
https://forums.iboats.com/showthread.php?t=167352 (carb adjusting)
https://forums.iboats.com/showthread.php?t=244013 (carb cleaning and rebuild)
https://forums.iboats.com/showthread.php?t=313963&highlight=compression (compression testing)
https://forums.iboats.com/showthread.php?t=283363 (How to test your boats fuel system...there is alot of detail in here)
Well I guess this will keep you busy for a little while!!! I hope it something simple!!
cajuncook1
