just got the trailer. when i got there i realized it was home made. since i was minutes away from picking up the boat and no other way to get the boat home, i decided to just buy it and fix it up later. tires are good, lights work and i had a 4 hour drive home. screw it.
so now i have it and working out just fine but need to move the tires back about 2.5 feet. seen below in the picture you will understand why. . . is there any particular things i need to do, other than measure perfectly?
i plan on going from the tongue to a certain point and measurement on either side. i am sure i can get that part figured out. just not too sure exactly where i should put the center of the tires. is there some measurement to follow or part on the boat that i want the tires to be?
