Well you might remember my post a few months ago about my onboard fire. I have been too busy with work to do anything about it until now. The first thing I did was order a Blue Sea Systems Fuse Panel with negative bus bar. This whole unit cost me $35, and it will be the central hub for my new wiring design. Now I have a simple and easy question that I am sure has been asked hundreds of times, but what size wire should I use for all my applications. WAIT... Now before you reference me to a chart with amps and distances, know that I don't know how many amps any of my accessories use. So that method has not worked. I actually tried to figure it out, but I now come to yall asking for advice.
Just consider my different accessories to use an average and normal amount of power. I need wire for the following accessories:
-2 small headlights that are mounted 10 feet away from my fuse panel
-Front and Back navigation lights, again mounted 10 and 3 feet from the panel
-Humminbird FishFinder 565, located 1 foot from the panel
-1000 gph bilge pump located 3 feet from panel
- 1 cigarette lighter 6 inches from the panel (used to charge my phone or power a small handheld spotlight)
Someone recommended that I use 10ga from my battery to the actual fuse panel. And then use 14 ga for all the accessories. Does this sound right? If yall have any suggestions please let me know. THanks!
